Power loss?
Chris205
  Many Things
Basically in the last day the car seems to have lost some of it's power, about 25%, it revs fine and idles fine although I have an idea that the baffles in the exhaust are loose and could have partially blocked the exhaust
the only other thing it's done in the last few days is refused to idle on initial start up, no matter if it was cold or normal workin temperature, if I held the revs for a few seconds then let off and it was ok
the idling is fine now but have loss of power
Chris205
  Many Things
Ph1's don't have much anyway so just hang with the corsas from now on and it will be fine ; p.
That will mean you'll be hanging with the corsa's as well then sunshine :p although your right, those 15 extra ponies really show on the road :rolleyes: im sure karl can back me up on that haha
Chris205
  Many Things
Possible lambda sensor?
cheers for the response mate, turned out to be the baffles in the backbox, been abusing it around without a backbox on to make sure its 110% the cause of the problem and turns out it is, although i now have a bad head haha
Chris205
  Many Things
but it did show in a car with more weight, lol and ill have more now, decat yo.
lol yeah mine did have more weight than yours tbf, somone weighing 90kg's ;-) then me at about 1000kg's hahaha weight defisit :( bad times
