5 gt turbo Raider & 172
I'm just trying eliminate things as i've got a very anoying sqeel, At idle you can barely hear it but when you drive its presant.
Now ive got the belt off i'm checking if theres any play in the pulleys and the p/steering pulley i have slight movement in and out, so was just wondering if this was the norm?
Every other seems fine so im some what confused, any ideas?
i dont run air con, so can i remove the unit and run the cup belt? and would the pulleys and tensioners be the same? so i could just get the belt?
