Problem with my desktop PC
  Suzuki Ignis Sport
Not sure why its happening, but i recently reinstalled/reformated my C Drive, so i have a clean copy of windows installed on it.
It was working fine for a few days, then i went away and didn't use it for 3 days, then came back to switch it on, and it doesn't get past the Windows XP loading bit... it just stops and my monitor switches to sleep mode, and the computer just stops working.
Anyone have any idea why this is happening?
However, before, there was a problem with my new monitor, it didn't happen until a few weeks after i bought and fitted it, I would be happily using it, then he monitor will switch to sleep mode, as it recognises there is no input, then a few seconds later, the computer restarts itself...
Weird, but why is this happening??
Thanks in advance.
  R26
Sounds a driver issue mate
Have you tried booting into safe mode to see if that works ok?
Could try last known good configuration as well
  Suzuki Ignis Sport
Yea tried last known good configuration but that did the same.
Will try safe mode later...
Wen i get through and past that bit, and able to use the computer, what should i do from there?... as in checking drivers are up to date?.. i have updated my video card driver as far as i know
  R26
Go into safe mode and remove the video driver and then try to get back into the windows the normal way
It could be that driver causing the issue
  BMW e46 320 Ci Sport
you can get into safe mode? hmm... i would run a windows repair on it and see what happens...will prob resolve it, if not, could be a bit more serious.
  Suzuki Ignis Sport
Right, some progress here! :)
Got into safe mode, so i tried restarting and going in normally, and its worked!
What should i do from here?
  Suzuki Ignis Sport
Right, updated my video card driver again, and seems to be working better than ever!...
Just my fans on my computer are really loud now.... need to switch some off now.... to make it a bit more quieter!
I did recently buy 1 gbs worth of RAM, but when i put it in, the comptuer started having problems, so i took them out and put my old ones back in.
What can i do so that the 1gb ones work?... whats the problem?
  R26
BIOS config mate for the new memory
Have you got your bios set to auto or manual settings for memory?
Auto should do it but if not you will have to find the exact settings for the memory via the manufacturer
  Suzuki Ignis Sport
My brothers friend built this computer, so i have no idea.
But all i know its an old one! lol
