problem with wiring angel lights
  Carrera 4S. Clio 172. M5
Ill probably get flamed for aiding and abetting criminal damage to a Clio, but:-
That pic just shows a fuse holder and a terminal ring, cant really tell much from that.
The AI,s are replacement for the sidelights, so they should be powered up from the existing side light wire.
If they are real angel eyes like the BMW ones, they will have a small exciter unit which should have 3 wires. Power, earth and the trigger.
Have you got the instructions, can you copy and post them up ?
How many wires are there on each headlight and what are the colours, that website didn't help at all.
There must be some instructions, surely .
Right, makes more sense now.
The red white wire with the tag goes on the positive terminal of the battery.
The connector in your hand connects to the sidelight wires which should just plug in after you remove the existing bulb holder.
The other black plug with the red blue and black wires, should just plug into the cars headlight plug, after you remove it from the old bulb. ;)
