It's unforgiving and inaccessible. Doesn't hold your hand at all. It feels to me very much like a PC game ported to console, which is a good and bad thing. Handling with the PS4 pad is much improved when you adjust the settings, but ultimately it's going to need a wheel to be properly rewarding. I like it.
How is everyone playing this when it doesn't come out until tomorrow?
Needs a racing rig. Unplayable on joypad. Certainly with the default settings.
Not tried them myself but seen this suggestion on the Av forums:what settings are people using for the PS4 controller?
We should setup a Cliosport Clio Cup race sometime, would be good......as long as its not in the wet.
Maybe consider Thrustmaster F458 wheel and pedal set (a bit of Ferrari bling) and a PlaySeat? Shop around and you may be able to get that for less than 500 big ones...Ok, so what wheel choices do I have for an XBOX one? Any wheel, gears, clutch pedals options that I can build a rig for with full racing seat?
Probably won't get past the Mrs but worth a go.
Nice one, thank you.Maybe consider Thrustmaster F458 wheel and pedal set (a bit of Ferrari bling) and a PlaySeat? Shop around and you may be able to get that for less than 500 big ones...
http://www.box.co.uk/Thrustmaster_T...BYSYbRZhQY2bYKVAh6OVf3ictwDcnDzGg4aAmlt8P8HAQ
http://www.playseat.com/shop/eu/uk/
Maybe.
That's probably because it hasn't finished downloading/installing yet..Has anyone had their hard copy early? Just sat down with mine and everything's locked bar "solo" and even that's only letting me drive one car on one track!! Gutted
What a knob I turned out to be!!That's probably because it hasn't finished downloading/installing yet..
Exactly this for me, I am undecided at the moment...Really can't decide about this.
Mixed reviews regards the AI (as with most racing games), and several comments about it being quite difficult (if your playing properly (aids off, manual gears etc).
I like a good racing game, but not sure I'll have the time/patience to give it the time it needs to then be able to get some good laps in and enjoy it. Also from reading the above it would be best with a wheel set up which I don't have (unless the original 360 wheel/pedals is compatible with the xbone which I don't think it is sadly).
I still have Forza 5 but that barely gets touched these days.
On the flip side, I'm bored of the games I have now so want something to trade them in for....hmmm
Now my controller is set up properly it's just awesome.
Done a few races with the formula rookie on the silver stone national and it's just brilliant IMO.
The cold tyres make it such a pain though, can't just nip out in a car to try it in free practice as it takes a few laps to get it up to temp.
I can't remember the exact ones but it's mode 2 and then pretty similar to the settings in Noddies post.What settings are you using for the controller? Ive changed to mode 2 but nothing specific...
Controller settings:
Steering sensitivity - 50 is linear. Lower gives you a more gentle curve. So try 35 if you find the car moving around too much in a straight line.
Speed sensitivity - at higher settings it'll stop you moving the front wheels too much at speed - try a setting of 60-70.
Filtering - this really helps. Try it at 50 at first then maybe higher. Will stop all that silly jittery car movement from very slight unintended pad input.
I prefer mode 3 for the pad then make the adjustments above. These are on PC though but no reason not to try on console too.
Anyone else trying the Bavarian Legend community event? Got my time down to 01:54:137, pretty confident of getting into the low 01:53s. The guy at the top has just set a new time of 01:47:935. Mental
Good time, I always find I get the first couple of tight turns perfect and brake too early or too late for the second set!Just had a quick go, 1m51.551 is my best so far after 6 laps. Still on default controls so will change them to what has been suggested and see whether it makes any difference. And to put use clutch as I didn't realise was an option, just had it on manual
