Hi,
I know this has been asked and answered about 1000 times on this forum before so I'll try keep it short and sweet but informative. I am from South Africa and the whole Clio Sport vibe down here isn't much, if anything... Which is why I am posting here - hoping to receive some advice on what to do. Here's the deal, I have an old Renault Clio 1.4l 8 Valve as my first car ( I am 20 years old ) and it has +- 175 000 Km's on the clock. Not so long ago my cam-belt broke while driving and this had to be repaired along with the valves that bent/broke, this cost about R6000 to repair. NOW the problem is that with the high mileage the oil rings have worn out, leaving me to top up the oil at least once a week before hearing a knocking or tapping noise ( Not good I know :dapprove: ). Parts here in South Africa are really expensive for Renault and so to replace Piston Rings, Cylinder Sleeves ( if needed ), Bearings and Gaskets etc.. will cost about R5000 ( Excluding labour ). Also, my exhaust manifold is cracked and I am pretty sure the rest of the exhaust needs replacing too. I would like to keep the car as it does need a lot of work which I am keen to do myself as I go along in my free time off from Varsity - Until I get my degree and can afford my own new car.
Now, my question is;
Would fixing such a high mileage, worn out engine which doesn't have a full service history be worth it ? How much longer would the engine last before something else goes wrong ?
or
Would it be better to find a replacement engine from another Renault and fit it to the car ? Something like a 1.6 16v or maybe a 2.0 ? :evil: I know its going to quite a mission but in the long run I think it will be better to replace the engine. Which engines would fit into my car ??
Thanks in advance, David
or
