PS3 2.5 Update warning
  BMW e46 320 Ci Sport
If you stream HD content via tversity the new firmware can cause issues with it. There is a fix avalible by editing the profile.xml file in tveristy to state v 1.5 rather than 1.0 (do a search and replace). Worth knowing cause i was well f**ked off with it last night having planned to watch iron man in HD!
Fortunately the fix works nicely. Otherwise you'll just get streamed content come up as unsupported media!
  Fabia vRS
thanks for that, i was wondering why some stuff like the small little previews had stopped working on mine, this might be the reason.
do you have a direct link with instructions?
took me ages to find them...erm...basically..
First update you tversity to latest versions...then
go to your tversity folder. Find the profile.xml file, edit with word pad, find a reference to PS3 Version 1.00 and change it to 1.50 (there are two), then save the file, restart tversity, restart file sharing, turn on ps3 and it should have worked. Worked for me.
  Fabia vRS
i just updated to RC4, this version only came out yesterday.
thing is, there are a load of references to version 1.0, not just the 2 you mention.....
<profile id="25fa8952-e706-4d74-bdf1-ff44a3222cb7">
<friendlyName>Sony PS3</friendlyName>
<manufacturerName>Sony</manufacturerName>
<modelName>Playstation 3</modelName>
<icon>/images/device_icon_ps3.png</icon>
inUASubstr - Used to identify the media hub we are dealing with.
Via web browser:
User-Agent: Mozilla/5.0 (PLAYSTATION 3; 1.00)
UPnP M-Search
UPnP/1.0
UPnP Browse:
UPnP/1.0 DLNADOC/1.00
UPnP/1.0 DLNADOC/1.50
UPnP HTTP Get of some media:
PLAYSTATION3
Note: The PS3 has similar user agent. The VGP user agent is a subsring of the PS3 and hence the PS3 profile has to be considerd before the Vaio so that PS3 won't mistakenly be identified as Vaio, this means the profile has to be in the file AFTER the Vaio
<HTTPHeader inUASubstr="PLAYSTATION 3|PLAYSTATION3|UPnP/1.0 DLNADOC"/>
<!-- The Name of the media serverdevice description file that should be used in conjunction with a player that
corresponds to this profile -->
<deviceDescription name="UPNP_AV_MediaServer_1.0.default.xml"/>
<!-- The container identifier media players of this profile expect -->
<contentDirectory shortUrl="true" friendlyFilename="true"/>
<!-- When transcoding is needed to which format should we transcode -->
<transcodeTarget audio="audio/x-wav" video="video/mpeg16" photo="image/jpeg"
onlineAudio="audio/mpeg" onlineVideo="video/mpeg16" onlinePhoto="image/jpeg"
adjustReadStartPos="false" audioFailFutureSeek="false" videoFailFutureSeek="true" />
<maxVideoInfo width="1920" height="1080" bitrate="20000000" fps="60"></maxVideoInfo><!-- MPEG1,2,4 at 1080p is supported -->
<minVideoInfo width="0" height="0" bitrate="0" fps="0"></minVideoInfo>
<maxImageInfo width="1920" height="1080"></maxImageInfo>
<minImageInfo width="0" height="0"></minImageInfo>
<maxAudioInfo sampleRate="48000" bitsperSample="16" nchannels="6" bitrate="1536000"></maxAudioInfo>
<minAudioInfo sampleRate="11025" bitsperSample="16" nchannels="1" bitrate="0"></minAudioInfo>
<fileInfo maxSize="9223372036854775807"/>
<mimetypeList>
<mimetype value="audio/x-wav"/><!-- WAV audio format-->
<mimetype value="audio/wav" rename="audio/x-wav"/><!-- Another mume type used for WAV audio format-->
<mimetype value="audio/wave" rename="audio/x-wav"/><!-- Another mume type used for WAV audio format-->
<mimetype value="audio/x-pn-wav" rename="audio/x-wav"/><!-- Another mume type used for WAV audio format-->
<mimetype value="audio/mpeg"/><!-- MP3 audio format-->
<mimetype value="audio/mp3" rename="audio/mpeg"/><!-- MP3 audio format-->
<mimetype value="audio/x-mpeg" rename="audio/mpeg"/><!-- MP3 audio format-->
<mimetype value="audio/x-mp3" rename="audio/mpeg"/><!-- MP3 audio format-->
<mimetype value="audio/mpeg3" rename="audio/mpeg"/><!-- MP3 audio format-->
<mimetype value="audio/x-mpeg3" rename="audio/mpeg"/><!-- MP3 audio format-->
<mimetype value="audio/mpg" rename="audio/mpeg"/><!-- MP3 audio format-->
<mimetype value="audio/x-mpg" rename="audio/mpeg"/><!-- MP3 audio format-->
<mimetype value="audio/x-mpegaudio" rename="audio/mpeg"/><!-- MP3 audio format-->
<mimetype value="audio/x-ms-wma"><!--WMA audio format--> <!-- WMA DRM, pro, lossless not supported -->
<codec name="WMAV1"/>
<codec name="WMAV2"/>
<!-- Not supported<codec name="0x0162"/>--><!-- WMA 9 Professional-->
<!-- Not supported<codec name="0x0163"/>--><!-- WMA 9 Lossless-->
</mimetype>
<mimetype value="audio/mp4">
<codec name="AAC"/><!-- MPEG4 AAC-->
<codec name="MPEG4AAC"/><!-- MPEG4 AAC (the difference from the one above is unknown-->
</mimetype>
<mimetype value="audio/m4a" rename="audio/mp4"/><!--MPEG4 audio format-->
<mimetype value="audio/x-aac" rename="audio/mp4"/><!--MPEG4 audio format-->
<mimetype value="audio/aac" rename="audio/mp4"/><!--MPEG4 audio format-->
<mimetype value="image/bmp"/><!-- BMP image format-->
<mimetype value="image/jpeg"/><!-- jpeg image format-->
<mimetype value="image/gif"/><!-- GIF image format-->
<mimetype value="image/tiff"/><!--TIFF image format-->
<mimetype value="image/jp2"/><!--JPEG2000 image format-->
<mimetype value="image/png"/><!-- PNG image format-->
<mimetype value="video/mpeg"/><!-- MPEG (1 or 2 program or transport stream) video format-->
<mimetype value="video/mp1s" rename="video/mpeg"/><!-- MPEG1 system stream video format-->
<mimetype value="video/mpeg2" rename="video/mpeg"/><!-- MPEG2 (program or transport stream) video format-->
<mimetype value="video/mp2p" rename="video/mpeg"/><!-- MPEG2 program stream (VOB) video format-->
<mimetype value="video/dvd" rename="video/mpeg"/><!-- MPEG2 program stream (VOB) video format-->
<mimetype value="video/mp2t"/><!-- MPEG2 transport stream video format-->
<mimetype value="video/mp4"><!-- MPEG4 video format-->
<codec name="MPEG4"/><!-- XVID, h263, DIVX version 4/5 and any mpeg4 ASP (layer 5) compliant stream (H264, AKA MPEG4 AVC or MPEG4 layer 10 or MPEG4.10, is not included here)-->
<codec name="H263"/><!-- h263-->
<codec name="H264"/> <!-- H264, AKA MPEG4 AVC or MPEG4 layer 10 or MPEG4.10 -->
<codec name="MP2" maxBitrate="320000"/><!-- MPEG2 Audio--><!-- never tested-->
<codec name="PCM_S16LE"/><!-- Uncompressed PCM Audio-->
<codec name="PCM_S16BE"/><!-- Uncompressed DVD PCM Audio--><!-- never tested-->
<codec name="AC3"/><!-- Dolby Digital AC3 Audio-->
<codec name="DTS"/><!-- DTS Audio-->
<codec name="MP3" maxBitrate="320000"/><!-- MPEG1 Layer 3 Audio-->
</mimetype>
<mimetype value="video/MP4V-ES" rename="video/mp4"/><!-- MPEG4 video format-->
<mimetype value="video/h264" rename="video/mp4"/><!-- MPEG4 video format-->
<mimetype value="video/mp4v" rename="video/mp4"/><!-- MPEG4 video format-->
<mimetype value="video/avi"><!-- AVI video format-->
<codec name="MPEG4"/><!-- XVID, h263, DIVX version 4/5 and any mpeg4 ASP (layer 5) compliant stream (H264, AKA MPEG4 layer 10, is not included here)-->
<codec name="MP2"/><!-- MPEG2 Audio--><!-- never tested in AVI-->
<codec name="MP3"/><!-- MPEG1 Layer 3 Audio-->
<codec name="MJPEG"/> <!-- Motion JPEG -->
</mimetype>
<mimetype value="video/x-msvideo" rename="video/avi"/><!-- AVI video format-->
<mimetype value="video/x-ms-wmv"> <!-- Maximum resolution for WMV is 720p but we do not mention it here -->
<codec name="WMV3"/> <!-- WMV3 is the codec version used for what MS calls WMV9 and only this is supported -->
<codec name="VC1"/>
<!-- Not supported<codec name="WMAV1"/>-->
<codec name="0x0162"/><!-- WMA 9 Professional-->
</mimetype>
</mimetypeList>
</profile>
can you shed any light?
thanks.
think it was this one mainly mate
