N80 new firmware available.
  Fiesta ST
Make a trip to your local Nokia service centre!
RM-92 dp v 13.0 (MCU SW 4.0623.0.41)
Date: 17.08.2006 Size: 101.5 MB
- New features
- When there is a headset connected then it is possible to close the slide
without ending the call
- Support for Microsoft Windows Media Player 10 has been added (No
support for DRM)
- Adobe PDF Reader has been added
- Mobile Search has been added
- Antivirus has been added
- FOTA (Firmware Over The Air) pull is enabled in some variants
- Backup
- Backup cannot read midlet when midlet is running before backup starts
- Contacts database is in use if client remains open during
backup/restore
- Java midlet data is not restored
- Panics if java hash information was not parsed successfully
- SIS files are not restored after backup/restore
- Midlets installed to drive other than (C not backed up or restored
- Package data file restoration problem when directory doesn't already
exist
- Backup/Restore failed to restore assigned Speed Dial numbers
- Bluetooth
- Improvements to stability of long term connections
- Switching on BT On ->off-> on can cause phone menu to lock up and
Disappear
- Browser
- Browser memory usage reduction when browsing many sites
- WAP Push correction for CSL
- Remove anti-aliasing for Chinese fonts
- www.kauppalehti.fi login causes connection timed out
- Stop browser loading images when memory low
- Calendar
- Meeting end date does not span correctly if user changes device
timezone to greater than current value
- Received recurring vCal entry is not saved to calendar
- Calendar alarm time imported incorrectly from S40 device
- Calendar editor erases subject field if you edit a full subject field
- Calendar crashes when changing repeat rule on an entry
- The anniversary alarm never goes off
- 100 consecutive alarms does not alert
- Due date and start date are mixed in ToDo items -> ToDo alarm can
not be stopped
- Calendar Options->Delete entry->All entries fails to delete exceptions
to recurring meetings.
- Change in time zone results in incorrect alarm date.
- System error and product freezes with certain Calendar note
- Lunar Calendar information is not available for dates before 1980
- Last instance of repeating meeting is lost, if repeating meeting is
modified in Outlook
- Unable to dismiss calendar alarm
- Repeating calendar entries
- Call
- Manual network selection freezes the phone if there is active PDP
context
- Display wrong operator name "1" in Manual Selection list
- Camera
- Bitmap corruption in thumbnails
- Camera localisation error fix (Localised Slovak) Camera: Wrong
grammar form of Automatic used in Scene Set-up
- Contacts
- Backslash character not properly handled when contact is copied to
memory card
- Data
- Call Back Access Point does not call back
- Rare Stability problems in TCP/IP
- Device Manager
- Display FOTA help for FOTA enabled variants
- Gallery
- Certain animated Gif files do not play when opened from Images and
Videos folder
- Screen becomes black for a second right after playing video file saved
in memory card
- Wrong Presentation icon is shown in the Gallery.
- BT Image Print - Phone is stuck at Cancelling screen
- PictBridge/HP475 - Phone hangs at cancelling screen after cancelling a
pictbridge print job on HP475 printer
- Video file is not played if opening from File Manager while another is
paused on the background.
- DRM image can't be zoomed in if the last right is in use.
- The display position of AnimatedGIF file is incorrect.
- New Camera Images do not appear in Gallery if Gallery is open
- The Animated GIF file, which has copyright protection of valid
Consumable Rights(count=5) can be played more than 5 times.
- 3gp playback incorrect when there are many images on memory card
- No help topics available in Music Settings View.
- Issues with recognizing new mimetypes
- Localisation
- Fallback when help directory is empty
- Memory Card
- Improve FAT mount performance by increasing FAT cache granularity
- Particular 256MB MiniSD card gives "Windows was unable to complete
the format" when formatting under WinXP.
- Memory card unlocking does not work if no card inserted while phone
booted
- Fix for memory card missing on soft reset
- Messaging
- Forwarded attachments visible as unsupported files in attachments
view
- Envelope icon doesn't stop blinking until phone is rebooted
- E-mail : It takes too long to attach contacts via e-mail.
- Message stays in outbox (until rebooted) after cancelling infrared
transmission
- Fixes MMS postcard image import size issue
- Obex crash with corrupted obex header
- Extra space at end of word when typing '/' character
- Can't receive message when using China Unicon dual mode card
- Add any file type to email attachment options
- Incorrect number is shown in note when fetching emails
- IMAP: Crash after trying to retrieve an email when there's no network
coverage
- Message Viewer takes 39 seconds to display long unicode message
- Link Highlight in automatic find does not wrap to next line in mixed
URL/number
- Data cannot be shown and deleted when save a large vCard which
received by IrDA.
- Multimedia
- Progressive JPEG codec doesn't compress heap after decoding
- Music Player
- Music player will be terminated forcefully at the time of selecting
searched data when the [Mark all] selected in track list creation.
- Networking
- Sending many UDP packets results in not all packets reaching the
recipient.
- Real Player
- Large chunk video break up
- Unresponsive RealPlayer after streaming
- Security
- No post after user cancel JAR download
- Exes are launched by Installer App before EULA is accepted
- Installer crashes when uninstalling software
- App. installed in other phone to memory card, shortcut to it is shown in
test phone
- Reset loop with certain (filesystem partly corrupted) MiniSD card
- Application Manager: Application loses list of installed applications
- Syncronisation
- Session ID in server notification (package #0) is not taken into use by
DM client
- Synchronisation fails if entering more than 2 entries in Calendar of the
handset with synchronisation setting as "None"
- UPnP
- Unknown authorisation request causes media server crash.
- UPnP - Apps Menu path in message for creating WLAN access points
is incorrect - localisation of path for all languages.
- Middle ok button does not work in result window
- Copying files with ‘&’ character in
- Home Network, fix for Music playlist sharing selections not working
- USB
- Mass Storage failure. Bulk Transport handles case badly
- USB mass storage class doesn't detach from Apple MAC/Tiger
- Video Telephony
- UE carried no sound or image after the following procedure UE
became out-of-coverage during VT communication. Then it originated
VT after the VT disconnection.
The following changes were also included in SW release 3.0618.0.1 which
was only available in some markets.
- Call
- DTMF tones now allowed for emergency call created with locked phone
- Applications
- RealPlayer updated – Improved handling for large chunk video
break up
- RealPlayer updated – Improvements to unresponsive RealPlayer
after streaming
- Settings
- Settings wizard updated to week 16 release for Taiwan country
Settings
- SIM
- Correction to SAT polling reponse
- Accessories
- Connecting doesn't succeed after disconnecting N616 car kit and
from 3G to 2G
- AD15 in Music Player mode has poor sound quality (until volume
changed)
Needed equipment for software update:
- Phoenix Service Software version 2006.20.9.148 or later
- Product Data Package v13.0
- PKD-1 Dongle & Flash Prommer FPS-10 or
DKU-2 USB Cable
- Product specific service devices
info from clubnseries
  Fiesta ST
I'd recommend taking it to a service centre!
This firmware is very new i'd leave updating until other people have with no problems
XXXXMESSING WITH YOUR PHONES FIRMWARE CAN DAMAGE YOUR PHONEXXXX
file available here: http://www.megaupload.com/?d=C7107U1Q
Flashing guide here: http://nokia.dogtoe.com/
I haven't updated yet, so cannot confirm if these links work. i will be taking mine to a service centre instead.
  Focus RS, 182 gone
nice, noticed my N80 plays up a lot, and now its started loosing the theme now and again and not realising there is a memory card in :S . Do they support sat nav yet??
  20VT Clio & 9-5 HOT
sweet.
still undecided what new phone to get with new contract...had the N80 and loved it but battery lasting 1 day is just crap, and the slidey was a bit annoying
1
172beast
I updated firmware once on my N80, will be doing it again, its easy enough providing you take your time. I've downloaded the file longy posts, seems to be correct, if I get time today I'll update my N80 to the latest firmware.
  Clio 172mk2
im still downloading all files at 12ksec :( , might just call in servce center later , but then i`ll have no settings on my fone for today, well till i get home
  williams and trophy
mine u can close the slider without locking the keys/cuttin off who u talkin to. does this mean it might already have been updated??
  RARE Unmolested Corsa sxi
ive done it. it works. brill!!!!
best to change the compatibility mode of phoenix to windows 98 if u have xp.
when u connect to computer there is a new option of media player, along with data, pict bridge and pc suite
  Clio 172mk2
yes there is media player , when u connect fone
just done mine , tbh i carnt see n e noticable differences. except it reset my phone lock code and i locked myself out for 5 mins
  Fiesta ST
did you use the updated Flash software? some people used the old version it still updates but misses some features.(eg acrobat, antivirus etc) people who have used the newer software say it's much better and improves the speed aswell as the added programmes.
  Clio 172mk2
well i used phonix 2006 like it said and i carnt see the acrobat reader or antivirus m ive got the virus one off nokia site but it says trial or subscibe.
  Golf Mk6 Oil Burner
Limowreck said:
Are these N80s easy to unlock?
N80s can only be unlocked by the operator. (i.e orange, voda etc). Obviously o2 phones are unlocked already. As far as i know there is no software out there yet that allows you to do it yourself.
  RS Megane DCi 175
How do you find your nearest Nokia service centre? Or will any carphone warehouse place be able to do it?
  1.6 Si
Sort of wanted to know that if i go to New York that I can put a local (US) sim card in it and use it?
  Golf Mk6 Oil Burner
^I have requested a code from Orange myself (not turned up yet). 20 quid charge but i dont think they are too happy about doing it in general.
1
172beast
Just done mine, only thing I've noticed is Virus checker and fonts on text messages changed, seems to run a tad faster I guess, shall see what its like over next few days.
