Hopefully this helps folks Whiteline are doing a 25% off sale at present and an additional £20 off of you are a new customer. I have just purchased one of their anti roll kits for £154 delivered. Which I thought was a bit of a bargain
Also their rear beam bushes are in the sale down to £36, I have used these for a while and they’ve proved excellent
BRR10Z Whiteline Rear Anti-Roll bar 18mm Heavy Duty Blade Adjustable Renault Clio X65 X85 1998-2013
Important Notes:Â 18mm - 2 point adjustable Engineered to 'Activate More Grip', Anti-Roll bars are principally designed to reduce body roll or sway. By reducing body roll, lateral loads are spread more evenly across the tires thereby increasing cornering grip and improving outright performance...
ukwhitelineperformance.com
KDT947 Whiteline Beam axle - front bushing
A critical rear end bushing for any front wheel drive vehicle as it absorbs all the cornering and braking energy. Over compliance leads to early wear and tear, especially in performance applications. Reduce rear end cornering squirm and improve braking efficiencies with the Whiteline beam axle kit.
