Pulled on wires now car wont even crank and serv light flashes
Car  ClioSport 172 Cup
Just finished fitting my component speakers and crossovers. I took the centre panel out that has the rear heated window switch, door locks and hazard light to help me get the stereo in as there are hundreds of wires behind it now!!. I pulled on them a bit hard i think and now everytime i put my key in the ignition and try to start the car the speedo needle has an epileptic fit for about 3 seconds and the serv light flashes.
Any important wire i might have damaged or pulled out that are on that loom or in the stereo area?? I'm really peed cause the speakers were all working fine and the car was running and now it isnt... it doesnt even crank and i have work tomorrow!:(
Yeah was gonna say you probably half yanked the earth off of snapped a wire somewhere in the loom. Not good as most of it is hidden. Silly sausage. :)
omg....what have you done. it proberly an easy fix but it just were all the wires are is gonna be the hard part to get to and finding it...
if you cant see anything with the stereo out take the dash top off, easy job, then you can see all the wires in and around that area, should be able to see what you have done.
