pulling issues
Car  172 ph2
hello
ok i have recently purchased myself a ph2 172 sport ive wanted one for a long time and finally went for it
problem being i got a bit of a lemon, to cut a long story short the guy who sold it to me didnt tell me that it had loads of advisorys from the mot station
so i got a car with a new mot but felt like it was going to pull itself apart at any time
so.. i got home and done the mot check online to find out what was wrong
... yer not good..
anotony k-tec
Date of test:
06/05/2011
Certificate issue refused (Fail)
Odometer reading:
83,816 Miles
Test number:
6889****1140
Test station name:
FORMULA ONE AUTOCENTRES LTD
Test station number:
1ALT19
Test station telephone number:
023****2233
Test class:
IV
Reason(s) for refusal to issue Certificate
Nearside Headlamp not working on main beam (1.7.4a) ----- done
Offside Headlamp not working on main beam (1.7.4a) ----- done
Offside Front constant velocity joint gaiter insecurely mounted to its housing (2.5.C.1a) ----- done
Nearside Rear Tyre tread depth below requirements of 1.6mm (4.1.E.1) ----- done
Advisory Notice issued
Windscreen has damage to an area less than a 40mm circle outside zone 'A' (8.3.1d) +++++++ get it filled free
Rear mount Exhaust has part of the system slightly deteriorated (7.1.1a) ----- done
Rear Exhaust has a minor leak of exhaust gases (7.1.2a) ----- done
Nearside Front Front suspension has slight play in a lower suspension ball joint (2.5.B.1a) ----- done
Nearside Front leaking Shock absorber has a light misting of oil (2.7.3) ----- done
Offside Front Shock absorber has a light misting of oil (2.7.3) ----- done
Nearside Front Tyre worn close to the legal limit (4.1.E.1) ----- done
Offside Rear Tyre worn close to the legal limit (4.1.E.1) ----- done
Nail in offside rear tyre ----- done
Spare tyre defective ----- done
O/s/r brake disc deteriorated +++++ needs doing
N/s/f tyre, cut in tred ----- done
O/s/f slight brake bind ----- done
so i cracked on a got the parts needed for the advisory work because in my eyes the car should have been failed on all that above
well the car handled bad with loads of knocking and pulling when i got it but after the work yer it was 110% better but i still get a problem
the car when travelling over over bumps the left side can pull around still or when accelerating and breaking hard
now as you can see ive replaced all above with brand new parts so does anyone have any ideas as its starting to annoy me now:mad:
thanks
I would say you need the alignment done as you have changed the ball joints. As for the knocks , narrow it down to the front or back of the car. If the rear knocks the usual suspect is the rear shocks or the front can be many things.
As for the other parts you renewed, well done for doing it yourself.
hi
yer i had the tracking done at ats with the laser tracking equipment after i completed all the work so thats spot on
it feels like it just wants to track the road its own way, so very annoying
the only things left to change would be the top mounts and track rod ends i think but would like to narrow it down
i only want it to stop pulling around :dead:
oh yes and all tyre pressures are equal
It's worth swapping the front wheels to the back and vice versa, and see if it drives straight then. Doesn't cost anything to find out.
i dont think im sure changing the wheels around will do anything, all tyres are balanced and brand new
if your driving along and have both hand on the steering wheel you can feel the wheels want to track the road hence the "pulling" it seems to have
i have also noticed if im turning right the ns wheel has a knock if there is a bump/dip in the road, i doubt its the ball joint as its new and have only heard it a couple of times
cheers
