Chris205
								Many Things
				So I've had this problem for the last few days, when giving the car lots of throttle, particularly in 1st/2nd gear it wants to drag me to the left quite violently, having to input a lot of steering to the right, making the car swerve all over the place.
I thought I'd let go of the steering wheel and see what it does, so I did, floored it in 1st, it nearly took me completely off the road, it very quickly pulled me to the left, as soon as power/torque built up at around 4k RPM it just goes nuts and wants to kill me, the same for 2nd gear.
A quick run down of the work done on the car over the last few months.
Jun - Coilovers set-up at JMS, running 16" wheels with goodyear eagle f1 tyres
Jun - Remove coilovers and go back to standard suspension, notice that both CV boots are split and spitting CV grease all over the inner wheel. Also notice passenger side track rod end is nackered, something I thought JMS would've advised me of when doing the allignment?
So I've collected a few parts, 2 x track rod ends, 2 x C.V boots.
So far I've only managed to get the passenger side track rod end sorted, as the car was now towing out too much I got the tracking done.
I've also fitted 15" wheels now with yoko parada spec 2 tyres. Also got a whiteline ARB on last night.
What's the verdict, nackered shock/spring? Tyres on the wrong way round, I couldn't see a direction indicator on them so not sure?
Could the fact only one track rod end has been renewed even though the other is fine? Could the garage have incorrectly tracked my car? My car still looks like its running a lot of camber, atleast more than I remember as standard, is there anything else on the suspension etc that could change the camber, bar the bolts in the hub/strut? Could the nackered C.V boots be causing more power to go to one driveshaft than the other?
Sorry for waffling but its got me quite worried
