QS5 Semi-Automatic to Fully manual?
Car  Renault meggy
Is it possiable to convert my semi automatic clio to a manual?
It's a Clio 2003 Expression QS5.
If it is what sort of price will I be looking at?
My reason for this is becuase the semi gearbox is crappy and I like using manual gears.
Any help welcome,
Thanks.
Forget it.
It cna be done but just forget the idea.
Why is that? Is it because it will be too expensive? bearing in mind that I have had to get my auto gearbox repaired once for £1000 and it will proberly break again.
Buy a second gearbox its cheaper and replace as and when it is unlikyl to break though that often then again they don't win any awardsas gearboxs go.
Cost and effrot are huge a proper job involves most of the car being rewired ne ECU etc plus need the pedal fitting etc.
Like edde said it isnt worth it, The cost in labor alone would be worth more than the car. Out of interest you'd need almost all the wiring, Ecu, Uch clocks, pedalbox gearshift box gearbox clutch and clutch cable.
:D yes its a simple job you will need the peddles clutch cable pressure plate and gear box, gearshift
the mount as well the sump is different but that doesnt matter cost 300 for a scrap motor
weight in when done get £160 which means only cost £140 to do any questions please
ask :cool:
:S as for the sunday automotive engineers
i would go back to school before giveing advice on here :S
