Question regarding de-cat, over run map and MOT...
Car  1eight2
I'm currently running an RS192 exhaust with de-cat. I fancy getting the over run (pops and bangs) map despite it not being favored much on here...
I've heard you cant use over run with a standard cat so how do you get by MOT with this?
Cheers in advance
Cheers in advance
You get around it either by fitting a cat for the MOT, or by getting a dodgy MOT.
You CAN use the overrun map with a standard cat, it will just blow it to pieces, but it wont be a problem having the cat and map on together just for the MOT itself as the pops and bangs bit of the map wont be active anyway.
