When changing the brake discs and pads, I understand that the brake fluid reservoir cap needs to be taken off, So that the piston can be wound back with a G-clamp.
When brake discs and pads are on, I need to slowly pump the brake pedal to set the brake pads against the discs right?
What i need to know is do i need to have the brake reservoir cap on or off when doing pumping the pedal?
And im not going to bleed the brakes on the day. So will that be ok?
Cheers if anyone can help![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
