QUICK HELP PLEASE - ELECTRICS
does anyone know which relay in a 16v does the fuel pump please? cant seem to find the info anywhere on which one it is
thankooooooo
its in the engine relay box on the n/s inner wing.one of the small black relays. i will check if you want,whats the reg year of the car?
its an l reg valver, but apperently it doesnt say anywhere what the relay is, if u could mate would be much appreciated!
look at the relay box from the passenger side.starting from the left the relays are:-
599-coolant pump relay
238-injection locking relay
234-cooling fan relay
oh sh*t sorry ill have another look.for some reason i looked up the fan relay sorry mate.i think the fuel pump is the large relay in the relay box.ill check tomorrow.you can gain access to the fuel pump wiring by an access flap under the rear seats.you could check relay operation by checking for a feed here.you cant see the fuel pump(only the sender unit)but there is a connecter block that you can see that goes to the fuel pump.
lets try again.
top row of relays from the left
234-radiator fan relay
bottem row of relays from the left
569-coolant pump timer relay
236-fuel pump relay
looked at your link.your fault sounds like a short circuit somewhere.is there a location number at the side of the fuse?
well im not sure which it is ill have to ask him, we were wondering if it could be the wrong type of relay put in N/O - N/C ??
check the relay pins and the connections in the relay holder/connecter.if all ok get a new genuine relay and try that.
if he pulls the relay out then it might not blow anyway because half the circuit now open so it wouldnt show any problems on the after relay side because that is now inactive.your best to fit a new relay to eliminate it.
