What removing and refitting lower inlet, do i need to jack the engine up? And if so where is the best place to do it as i really don't want to crack my sump!
Not 100% sure but i dont think you meed to jack the engine last time i checked, you remove the front bolts and then one on the left hand side which goes in sideways. The one on the side is long so might be a tricky to remove if you have A/c
I use an engine hoist, JUST fits under a car (std height) so you dont have to put it on stands.
Then remove the side mount and jack the hoist (attached to the cambelt side lifting eye) a couple of inches.
