R888 Tyre life?
I have heard 4-5 track days and on the road they wear very easily due to the soft compound so I would suggest only using these for track use as on the road you will be replacing them before you know it
I've done 3 full trackdays and a ring trip on the current set (not driven to/from). They still have tons of tread left. It really does depend hugely on driving style though.
Make sure you keep hot pressures 30psi or less (cold - very low 20s front, mid 20s rear). I personally run them at about 28-29 hot. If you run them higher than that you'll wear the centres down in a day.
thanks for the advice was thinking of getting a set for my trackdays and my be use them on the road but it sounds like a stupid idea
chears callum:)
i get around 3 to 5 track days it all depends on the temp and what the track surface is like i put two new r888 when i did spa last year with Renault sport and almost destroyed the two fronts in one day
