race brake pads
Car  wrx sti ppp (305bhp)
i had some ferodo race brake pads fitted the other week, says ferodo FCP406H on the box, and they seem to squeal alot when braking? this normal?
Race pads will squeal a lot till you get them warmed up.
Around town driving, they will squeak.
Should have gone for fast road pads (Green Pads EBC/DS2500) @YozzaSport
FCP565H is what we use
strange as the megane use the same caliper, god knows why they list 2 different pads that are the same!
im sure theres something wrong with these pads, ive just been out for ages thrashing the car at high speeds and they still squeal seem to get worse when warmed up???? are they fucked?
No, my race pads do the same. If you get them even hotter they stop squeeling.
The squeeling on mine seems louder when you just got them really hot and they are cooling down.
When mine are really hot and you come to a stop you can actually hear them grinding into the discs. Not sure whether thats good or bad really
hmm, its starting to piss me off with the aquealing noise, wish i never had them put on, what race pads do u have on mate?
its on a mk1 1991 16v, so not the same setup as you...
I dont have a clue which ones they are. They are the ones they used to use when they raced the clio 16v cup years and years ago.
Yeah the squeeling is quite annoying at times, people look etc. People probably think that my car needs a good service or something but i got them for free and they are the first brakes that i havnt managed to glaze over doing 80-0mph repeatedly on dual carriages with roundabouts, so im keeping them till i can afford some fast road ones.
When the brakes are glazed over the disc and pad surfaces look basically like two mirrors and as you can imagine they dont grip each other very well. This normally happens from them getting too hot. When they are glazed over they do also squeel but yours shouldnt be glazed over. Glazed over squeel is a slightly different squeel from what I remember.
You could get race pads to glaze over in a race situation, but you would struggle to get that much heat into them on the road.
My race pads squeel but if i look at my discs they are a lovely grey matt colour.
FredYozzasport said:
did you remove the caliper shims before fitting the pads??
aint gotta clue what these r but we took off these thin plates?? said i dint need em with these brakes????
These thin plates (shims) are slightly softer metal designed to be placed between the brake pads and caliper pistons. Because they are softer they reduce/eliminate the very small vibration on the pads that cause squeaking.
So if you removed them, put them back. It should reduce/eliminate the squeak.
You can buy more or small pieces of rubber can be used (I had some come with my Green Pads).
just a quick question, when u take off the caliper do i need to push the piston in straight away so it fits back on, as my mates dad sorted this all 4 me?
This is not a definitive guide or anything, but...
1. Take the engine cover off. Loosen the Brake reservoir cap (this must be done otherwise you can't push the piston back into the caliper).
2. Remove wheel etc.
3. Remove brake pads (no need to remove the whole caliper (Subway)).
4. I use a screw driver to push back the piston (make sure you don't get grease or scratch the discs).
5. Cover the metal side of the pad with the shim plus a dap of copper grease.
6. Fit both pads back in (if your like me, you'll realise you haven't pushed the pistons back far enough, if so repeat step 4, LOL!).
7. Refit caliper and wheel.
8. Repeat other side.
9. Now replace cap on brake reservior.
10. Pump pedal, start engine, test brakes.
This is what I did more or less...
did it earlier, didnt need to remove brake fluid cap, the squealing has almost stopped, theres a slight squeal from the right side but its nothing compared to before, im surprised i did it with out any problems, and 99% of the time there is!!!! cheers for the guide mate!!
It might be worth just loosening the cap then re-tighting, helps the trapped air out of the reservior.
I sure it won't matter too much if you don't, I'm sure someone else will post if you should do it.
Glad you've got it sorted...
when using DS2500's on the 172/182's you HAVE to remove the caliper shims (the thin bits of metal) otherwise they WILL squeal!
i didn't get on with reds, yellows are a race pads yes
for the clios the BEST pad available (in pure performance terms) is the PF97
ive got someone selling them at £50.00 brand new down the road from me. He bought the wrong ones, so im gonna kop them off him.
