Rack mounts
How easy is it to replace the rubber mounts for the steering rack? How much will the cost and can you buy just the mounts? If you cant buy them are there any DIY solutions to this problem?
Also is there a test to see if the mounts are worn?
  172 cup,s2 rs turbo
not sure if the rubbers are avaliable separatly but i can check if you want.would need the vehicle details in the oval part of the chassis plate.
