radiator help please!
  Sunflower 172 :)
i have broken my radiator on my 172. i have tried using bar weld but hasnt worked for long. i have my radiator off my old 1.2 t reg clio will this work? cheer airs
I don't think it will, there is more "area" on the 172 rad and I think the temp sender is different.
Check with Edde or Fred though.
oops: fred beat me to it.
is it worth risking causing major damage to your car by not buying a new one? try specialist breakers first
01254 386661 ask for jane, nic or matt, tell them i sent you
ok cheers fred will give them a call 2moro and see what they can do. guna try sumore bar weld tomoz nd see what happens. na it aint worth risking mate your rite. cheers again
you think it would do damage? i have done 10 miles or so and all water just dissapeared from the bottle and it was at max mark! so must bed a reli big leak.
Forget using the 1.2 one way to small.
As fred said try matt he can get hold of brand new ones at discount.
