-Radio code needed-
  RB 182
Ive recently had a problem with my battery and needed to charge it after if was completely flat.
I now have the problem that the radio needs a code for me to use it can any one help, please!!!
  Renault Laguna Coupe
Your dealer will be able to tell you the code. Mines on a little print-out stuck in the front of my service book.
after youve switched the unit on itll say 0000. You use the remote to enter the code.
to enter 1234...
turn thumbwheel until you see 1 - press MODE (the lower button on the remote)
now turn thumbwhell until you see 2 as the second digit - press MODE again.. etc etc until your code is complete. When complete press and hold MODE and youll get a bleep and youre in business.
  RB 182
:D I pressed every button apart from the mode button on the dame car, i never use that usually thats why. Ill just go and try it.
Thanks Mike
  RB 182
Well thanks Mike, did as you said and then pressed in the mode button when id finished and worked a treat. Its even kept my presets!!!
