If you mean the gel to make the original better Theres a guide in the guides section
if i remember correctly its just ibuprofen gel
but id double check first
Not sure exactly what you mean but.. if all you're after is something to make the sensor contact properly with the windscreen, then all you need is some hair gel. I did this on my first Clio. It'd had a new windscreen and the sensor wasn't stuck back on right. I used "No Nails" permanent strips to hold the cage to the screen and then just smeared some hair gel on to the sensor before pressing the clips together. Not sure if this is what you're actually asking though :S
