Rainbow or Inifinty Speakers?????? HELP !!!
  Clio 182 built in Sat Nav
As the title says...which components shall i buy for the my 182.??
I have read the countless threads about speakers (all very helpfull) and its always these 2 makes that keep coming up...but which one is better??
Also if anyone has got decent suggestion for rears then lets have that aswell. i am not putting a sub in, so need some mid/low range drivers for rear.
cheers and a merry xmas to you all
drive carefully..!!
Adam
Rainbow everytime if its between them two.
infinity is old technology.
im a supplier of both and i choose rainbow for personal recommendation.
Also theres no real alternative to a sub if u want low range sound. You can only get a set of kick bass type speakers which only come in component form. which obviously isnt a perfect choice when you have only a place for a coaxial speaker as standard.
and even these only give you an increase in mid bass. which may be ok for what u need.
they are a nice set of speakers!
Kick bass speakers, well, without going into too much detail, they have a quadruple (sp) spider instead of the usual 1 that comes in most component mid bass/range drivers. this allows the speaker to emphasise the frequences between 80-160hz more than the non kick bass versions.
Ideal for non sub application systems, however not perfect if you want a sub.
So for what your using it for, the kick bass type components would be what your after, to give you a bit more 'tump/thump' in the front that normal speakers dont provide. however in the rear you will have to go for normal full range coaxials. However all rainbow speakers offer a good mid bass sound when put in the right enclosure.
You don't live anywhere near reading do ya mate? to save you ordering on line, i could sell you them from my shop and do ya a lil discount to.
live in halifax!!
need a 4 channel amp and some speakers for the rear as well, so if its a good discount then we can prop sort something out
Adam
