Iv noticed over the past couple if days, when i change down from 4th to 3rd or 3rd to 2nd (i blip the accelerator for a smooth change, just a habit), i occasionally get quite a loud pop, as awesome as it sounds it cant be doing the cat much good.. Would blipping the accelerator be causing this?!
Also since it started doing it the engine management light has came on which my scanner tells me is the upstream lambda sensor (1st one) could this be a possible problem too?!
Sent from my iPhone because i can...
