Ratchet spanner recommendation
thecrim22
  various
As above what decent ratchet spanners are people using? I prefer an angled head instead of a straight spanner and they need to be decent quality to put up with working in the s**t and gutters.
Ive got a set of snapon ones in my garage box but wanting a complete set for the van (8-19) ive currently just got a 10,13,17&19 in the van
I dont fancy spending £400 on a set.
Ive seen a set of bluepoint ones on tbay
https://www.ebay.co.uk/itm/173615907160
but not sure if they genuine as they are different design than whats on snapons website, but they do look the same as ones ive had in the past.
thecrim22
  various
Halfords Advanced flexi head ones
Had mine for a good 12 years, only issue I've had with them is getting them wet and them being a bit sticky. Overnight in some WD40 and they're spot on for a few more years
Not a fan of flexi head ones, twatted my knuckles too many times🤣🤣
Brigsy
  T.Turbo
The halfords advanced flexi head ratchet spanners are decent for the money but the flexi head pivot wears out fast with regular use, making them a bit floppy c**k like which gets annoying fast. On plus side halfords replace them no quibbles.
Id prob go bluepoint if used all the time.
thecrim22
  various
I won a set of Halfords advanced ones at work years ago, they're pretty good, gearwrench make a nice set of Flexi head ratchet spanners too
Yeah im not after flexi heads, used them in the past and usually end up twatting knuckles off of something, or they get loose and when you're in a shitty place they flop away from where you're trying to get onto
Brigsy
  T.Turbo
Yep knuckle breakers the flexi head when loose. I need a set of angled ones, and reversible on the lever like a ratchet. I need to invest in a new set/angled set myself.
I did borrow a set of snapon double jointed flex head years ago to do a tricky set of glow plugs and they were mint. Not sure how well they wear but stayed in exactly the right place/solid in use. Were quite new set though.
MAXRUNDOWN
I've got a few (not a full set sadly) non flexi angled head spanners, some Bahco combination ones with a change over lever which are very nice
and some double ended snap on ones which have a much bigger angle but they're the riveted stamped steel ones so they're not as nice to use
