It doesnt move surprisingly but you can hear it rattling when your in the car and its moving. But the loop what your talking about there is a lot of movement in that yes. Ill try that now thankyou pal.
Right okay then yeah, I can’t seem to find what the problem is I’ve since looked at the loop latch and the large bolt that holds it in place is nice and tight anyway. Since removing the rear plastic to get access to the bolt the light hasn’t come on since thankfully but the rattle is still there.The loop does have a bit of movement naturally for it to locate in the latch on the boot door, so the adjustment screw won't change that.
If the boot door doesn't move when you give it a pull whilst it's closed, then I can't see how its bringing the door open warning on.
Ive found it to be these contact points you talk about mate. Could i get these replaced at all?Look for the rubber contact points that the Boot lid sits on. These flatten over time, I have the same problem.
