I've had my Clio for about 2 months now and apart from this annoying fault it's been ok.
The problem occurs whenever the car is driven over a speed bump or a relatively large pothole.
It is a "rattle" noise that lasts for about a second but as it happens you can see the lights dim and the LED clock display dim slightly. If the radio is on then that slightly breaks up the signal. It definately sounds like it is coming from the fuse box.
Just wondering if anyone else has had this problem and if so what the fix/problem is?
My first guess is a dodgey earth somewhere.
