Rattling from sunroof
  Clio 1.6 16V
Ive had problems with MK2 PH1 & 2 sunroofs, They tend to creak over bumpy surfaces when the body flexes (especially during hot weather). Found that the rubber finishing bead covering the sunroof suround/headlining makes the noise (rubbing). Remove it and re-assemle with some vasaline then problem normally goes away. Try putting some vasaline on the rubber seal if you have a manual sunroof. May also be a cable/mechanism rattle if you have a lecky sunroof.
i have this same problem on my 99 clio - its REALLY annoyin
its asif the roof is creakin round the sunroof area
will try the vasaline tonight ;)
