Rear Bearings right part??
  RB 182 cup,astra sri
Hi guys
i just bought rear bearings for the clio 172 cup.
they say saxo on the side, i just wanted to check that they are the correct ones before attempting to fit them etc.
how can i check that they are the correct ones?
any help on this would be greatly appreciated
thanks
craig
  BMW M135i
You'll need a press to get the old ones out (if not new discs) and to get the new ones in. The saxo vts/vtr uses the same(ish) rear brake setup so they should be the right ones.
i have the new discs.
my dads work can get them pressed in, or freeze the bearing so that it will just slide in.
i take it the bearings should be flush against the lip of the disc with the circlip holding it in in the middle rim of the disc? if you know what i mean.
