Rear brake pads
Car  Clio 182
Time to change my rear pads, track car only so just wondering if there's any point going from standard pads on the back as they don't exactly do the lions share of braking.....worth going for a track pad same as up front??
I don't mind paying for what I need when it's making a difference but I don't see the point in throwing in £100 pads on the back if I'll see no gain is what I'm getting at really.
"Text book" you run a slightly less focused compound in the rear to the front. You'll be fine with a decent oe in the rear like Brembo running those fronts
Thanks, good advice.
At what point would I need to upgrade the rears then would you say, I'll probably go for a more aggressive pad again when the rc5's are done.....was thinking ds1.1 next
You won't see any benefits from race pads in the rear.
Just stick to the Brembos and you will be fine.
The rear brakes just about clean up the rusty discs after washing the car. [emoji23]
