rear brakes
  182 FF Arctic
im looking at doing my rear discs & pads but never done rears before i did the fronts last week no problems but with the rears what do i need new bearings etc or just discs & pads?
  CLIO RS CUP
you can remove the ABS ring from your old ones. But if you buy OEM disks they have bearings in, aftermarket ones come seperately and you'll need a press to put them in. Easiest to buy them with bearings in!
  Now Sold :-(
NWperformance usually have good deals on OEM rear discs with the bearings and abs rings already fitted. For what they charge don't think you can do better IMO.
Very easy to change as long as you have a 32mm (I think) socket for the hub nut.
