Rear Breaks
  clio sport 172
hi can any one tell me if my 172 will have the rear disc with a bearing or with out as jsut found out there are two types of rear disc avaible and not sure which one i need thanks
  ValverInBits
All cars have wheel bearings. The clio bearings and discs are pressed together. It's not possible to press bearings at home, you need a large press.
If you get discs without bearings, then you need to have your current bearings pressed into them.
If your looking after the car, get a set of discs with bearings. You'd be really annoyed if the rear bearings went 4 months down the line.
