Rear camber adjustment
Greeny.
  440i + 182
Firstly is it worth messing with the rear camber for a fast road, a few track days a year car? If so where can I get some shims from and what else would adding more negative camber affect if anything?
  Lionel Richie
yozzasport do the rear shims for £30 a pair IIRC
on a road car i wouldn't c**k about with it, track car depending on what you're looking for, then yes
Greeny.
  440i + 182
Not even for an extra -1.0 negative? A waste of £30? Are they easy enough to fit out of interest as ive not looked into it at all yet.
M
mini-valver
If you stick a degree of negative camber on each wheel, you'll need roughly 20' of toe out on each wheel too. So thats another £30 ;)
Edit: Unless for some bizzarre reason you'd want mega toe in as they toe in slightly anyway as standard I think.
  Lionel Richie
4bolts per side to fit
mini makes a valid point, but i think the smaller angled shims are less money, but don't quote me on that
M
mini-valver
We should date! x
John @ Rsport wants £20 a shim I think, robbing cnut.
