Rear Camber
  Cup Packed BG 182
Is it possible to dial in rear camber by using some washer on the bottom 2 studs out of the 4 on the stub axle rather than buying shims?
  Qashcow
i used 0.5mm washers under the two bottom bolts and spaced the hubs out 15mm also, looked gangsta yo, seemed alright on track but then i hadnt driven it hard for 7 months so couldnt tell you if it was worse or better than standard.
looked cool though, an i had enough powahhhh to make up for any s**t cornering ;)
