rear clio and diamond badge
  b/g 182, meg tourer
clio comes off easy. just carefully prise/pull it off. try not to snap it or the pins that hold it in
the diamond isn't so easy. i hae taken mine out despite ppl saying it cant be done...
well it can
you need to take off the plastic pannel in your boot, undo the screws that hold the boot release on and the whole unit will come off.
carefully prise/or tap the back of the diamond with a hammer and a rar to protect it.
hope this helps
MRBILLYUK
  FF Jeden Osiem Dwa
The Renault diamond is located with 4 lugs and , inside the diamond there are 4 tiny little lugs that stop the diamond coming loose .Like clio luke says , you'll have to take the whole mechanism off . Have a look in a haynes manual if your unsure .
  b/g 182, meg tourer
the 4 lugs are each glued tho. sometimes need to scrape the glue away from the back.
takes a fair bit of force to get the diamond out
