Take the plastic trim off of the inside of the boot, iirc it's 1 torx screw then it's just clipped on. Then undo the 2 or 3 bolts holding the actual boot hande on. Then if you look at the back, you'll see 4 clips that are holding the diamond in place. These are glued on. Tbh i just popped mine off with a screw driver without taking it off the car, and clipped it back on.
