Once youve unbolted the rear diamond, you have to use a screwdriver to push the tabs out, the diamond is sort of plastic welded at the tabs, should either push back in snugly or use some silicone/glue.
in case that doesn't quite read clear, removing the 3x 10mm nuts removes the boot lock handle, the mound that the diamond is attached to. once you have unscrewed this you can then remove the diamond feom the mound, mine was fixed using double sided tape so took a bit of working to get it free.
