rear disc question?
Car  Fiesta ST3
got all the bits for doing the rear disc and pads but i have a couple of questions before i start them..
do you re-grease the stub axle when you put the new disc on? and are the hub nut's a use once only item or are they ok to re-fit?
do i need to do anything with the new disc i.e grease the new bearing?
aye you can do, won't hurt, make sure the spacer goes back on the correct way, you're not meant to reuse the hub nuts
what size is the hub nut?? or is it a renault jobby if so does anybody have the part number??
just been upto renault and got 2 hub nuts the part No on the invoice is:- R77 03 034 250 ---- R7D NUT £2.66 Each
Fred, im just doing the rear discs on mine, the spacer i think is quite obvious which way round it goes but dont want to get it wrong, which way is it meant to go?
