Monaco 172
which one is it?
Vented or Solid Solid Diameter (mm) 238 Thickness (mm) 8 Minimum Thickness (mm) 7 Height (mm) 74.5 Bore (mm) 49/52 No. of Holes/Studs 4 - (-ABS Ring/Bearing) Position R
or
Vented or Solid Solid Diameter (mm) 238 Thickness (mm) 8 Minimum Thickness (mm) 7 Height (mm) 75 Bore (mm) 52 No. of Holes/Studs 4 - (+ABS Ring/Bearing) Position R
cheers
oh and 90% certain it has the bosch calipers.
or
cheers
