Rear disk and pads
  02 172 pre ESP Monaco(13)
Got a 02 172 FF, there was a noise plus vibration coming from the rear left wheel, orignally thought it was tyre noise as I'm new to the clio, it got worse and thought it could be a wheel bearing, so took off the wheel to spin it and check. The pad is basically on the disk, probably warped disk or the the pads have seized on. Obviously going to get it seen to sharpish, but does anyone one know if this would cause any other damage to that area that I should get checked while its getting fixed
  CB600FS
When you replace the disc, more than likely it'll come with a new bearing pressed in ready to go so in effect your killing 2 birds with one stone. Should cure it.
If the pads are badly metal to metal, they'd cause noise and all sorts of problems.
