rear door panel removal
  renault clio 1.4 16v
hello
i'm having difficulties with the rear door panel removal.
i tried to remove it because of a malfunction of the automatic opening (vacuum or electrical)
i unscrew all the screws but something is fixing it, maybe it is glued or it has some additional plastic clips
since i dont want to destroy it please can you tell how to open or if you can have some pictures of it opened it will be fine
thanks
have you taken the hidden skrew out of the door handle? there is also a bead of sealer around the edge of the door card however if u run your fingers around the edge you sould be able to pry it lose and pop the clips as well, there are some inner clips but if it dosnt move with moderate force thenuve missed a screw somewhere, may sound stupid... but make sure you have removed the window winder handle as well...
yes I'm sure i removed everything, handle and so on
maybe if I can see some pictures I can re try it
