Rear headlight bulb not working !
  Gordini 182
Hi,
I have the phase 2 clusters and my rear bottom right headlight bulb doesnt work, i have brought a new bulb still not working.
Any help would be welcome..
Thanks in advance.
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
Fuses okay? Checked the wiring is okay and that you have +12vwhen you turn the lights on?
TheEvilGiraffe
South East - Essex
Double check the wiring .. obviously the bulb works. Am I right in thinking you've put ph2 lights on a ph1 ? So therefore have changed the wires in the connector block...?
IIRC, that side always seems to suffer with corrosion as well... just as a point of reference.
If it all seems OK, swap the holders over from the LHS, and see if the same situation arises with different bulbs and holder... if you see what I mean.
Good luck ! ;)
