Rear Nearside Foglight
  2005 172 Clio 1.4
Hi,
Just had an MOT failure on my 172 Clio for (among other things) the nearside rear fog light not working.
I've tried numerous bulbs and nothing.
I swapped the bulb holder to the offside lighting harness and it worked which would indicate that there wiring itself is damaged somewhere - my first suspicion was corrosion on the bulb contacts.
Has anyone had any experience of this fault and if so, is there a common place where the wiring can get damaged?
I wouldn't imagine it is a fuse or rely as the other side works fine unless there's something I don't know about the wiring.
I don't have access to a voltmeter right now
Any help would be appreciated!
