Rear shockers on a 04 182?
  Astra CDTI SRI
Where can I get them on the net?
Had a search on google, but couldn't find anything.
Any ideas?
Renault only.
All Mk2 phase 2 are he same fitment 172 on es will be the closes to what your ar needs Bilsten do an OE replacment set but there only a few quid short of Renault prices and since there not perfect for a 182 why not go buy the proper ones.
  Astra CDTI SRI
Only problem is that I have stuck lowering springs on.
Will that not invalidate the warranty?
  Vectra :(
If you have your orignal springs then swap them back before you take it in. They will never know :quiet:
J
JACKO CUP 172!
am tryin to get renault to change mine on warrenty but they said it is only misting so no is the answer.
  Astra CDTI SRI
I get a dull "thud" from the back passenger side shocker.
And there is oil leaking from the bottom.
Does that sound like the problem everyone else had?
  tiTTy & SV650
you'll see oil on the shaft, you'll get lots of back end action which is good fun and it'll thud like you say.
i've had 5 under warranty all rear
