Rear speaker
Car  Clio 172mk2
right tomorow im planning on adding 6x9s onto parcel shelf,
could some one tell me how u get to the rear speakers (pics if possible), also what kinda screws hold the original speakers in (torx etc)
thanks alot cheers
Remove rear seat (bottoms only) and pull off speaker cover, unscrew screws and unplug speaker wires!
Not that hard but if you want pics I get some later!
main thing is getting the panels off dont wanna damage it,
thanks alot , n if theres pics mutch appreciated
good sounds easy,
also going on quality of front speakers i believe there 13cm ones, wich would be better the factory front ones or some 2 year old kenwood 110watt peak power speakers
[Edited by biojo on 23 July 2005 at 6:27pm]
First upgrade the std headunit as replacing std speakers you will not find any difference as the power out put is fairly poor.
[Edited by msa182 on 7/23/2005 6:29:14 PM]
Also you have comp. speaker in fronts, ie. small speaker (tweeter) on dash and mid range in door
ye i gathered that the standard head unit is a bit w**k , but it has a 6 disc changer , n dont wanna buy a alpine one at 300 yet as i wanna be able to get a ipod for it.
so just wanna get it a little better for now
To be honest mate I wouldnt bother changing any speakers until you change the Hu as there little point, and a waste of your time!
to be honest i just want all this done so when i change headunit itll only be a 20 min job
then im not rushing about one day doing it all
