Rear windscreen wash nozzle
  Renault Clio Mk2
Searched the forums but couldn't find this exact problem!
Basically all 4 of the front nozzles work perfectly, however the back one, does nothing at all? Checked fluid level, and when I go to spray it I can hear the motor whirring, anyone had similar or know a fix? Car is a mk2 ph3 non sport clio 1.2 16v if that info is needed, many thanks in advance :smile:
Also tried clearing the nozzle with a safety pin but nothing?:/
  Clio 2.0 16v 182
Common problem is corroded tube in the spoiler or stagnant build up in the pipe. The tube runs along the interior nearside (from the a frame and over the rear quarter). Mine is clear so I can see if it's blocked. If yours is blocked getting a clear tube is a cheap and convenient mod.
