Rear Wiper won't work properly.
Ok, so basically this isn't something I've seen posted before, my rear wiper will clean correctly and does the full 170 degrees its meant to clean when told to.
However the wiper won't get the top part of the window. The bit where the window curves my wiper won't clean because the wiper blade won't bend over the contour of the window. Hope that makes sense.
It's really annoying and I bought a new blade like 2 months ago to fix the problem but it still won't work properly, any ideas?
Please help with this, its really weird and annoying beyond compare.
Mine did this until I read on here about a bodge whereby you can file some of the plastic away where the arm pivots. This allows the arm to articulate more and sweep more of the screen. It does work, but may require a bit of trial and error. Search on here for the the thread that includes pictures of where to file the material from. Hope that helps.
