recharging air con?
  Clio 182
Made for top up, remember when I worked there I go training for it, if I've still got pressure in system it should work, but if empty then chance air con is goosed. Tbf most garages do leak test/ refill for around £50- better that then waste money on the can
Andy_con
  clio 182
trouble is we had two different garage do a leak test but both couldn't find the leak.
its odd cost one garage read a fault code that said air con pump was faulty, but once re gassed it pumped out cold air just fine
  Mk4 Mondeo Estate
Don't use these. Air con systems require a specific weight of gas to function correctly. Over filling an A/C system will mean the failsafe kicks in, to prevent the system from being over pressurised.
Chrisgti6
  Too many
My local tyre place only charge £35 to vacuum and refil the system to the correct wieght.
