Recommended clutch for 172 track car?
Hi everyone
I'm currently having my 172 Cup track car recommissioned.
The engine is out, it's having a new belt set, manifold and while it's out I would like to install a gripper diff and clutch.
What is the consensus on clutches for these cars?
I'm out of touch and could use some advice,
Many thanks
If you're not running boost I can't see the point in running anything other than the standard clutch, maybe if you fit an aftermarket flywheel that requires it?
The standard one is a tough unit. Just swapped mine out at 91k because the release bearing had gone, it still had quite a lot of life left in it. That's with track use as well 😊
